L-82 Valve cover paint
Old 06-30-2004, 10:27 AM
red topless gator
red topless gator's Avatar
Default L-82 Valve cover paint
Does anyone know what color/type paint to use on L-82 valve covers on a 79, close to original as possible?. Thanks..LT
Old 06-30-2004, 10:52 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Default Re: L-82 Valve cover paint (ltinnell)
Valve covers are semi-flat black with bare metal accents on my '80 L-82.
Old 06-30-2004, 10:55 AM
Disco_Mike
Disco_Mike's Avatar
Semi gloss black. The top of the fins are unfinished.
[Modified by JoieDeVie, 10:56 AM 6/30/2004]
Old 06-30-2004, 11:48 AM
1LE
1LE's Avatar
L T ; For a different twist on the covers; I bought a pair of used L-82 covers a few years ago and they have been sitting in the garage collecting dust. A few weeks ago, I had them bead blasted and was going to repaint the valve covers black. Brfore doing this I thought I would play around with one and see if I could polish it. I started sanding with a 320 grit, went to a 400 then 600 then 1200grit. The valve cover started looking very nice. I continued with a 1500 grit, then some polish rugue red then white and finally with some mothers polish. The valve cover looks great. I will be doing the other one this weekend. The polished aluminum is the way I will leave mine.
Old 06-30-2004, 11:51 AM
Pauld
Pauld's Avatar
Default Re: L-82 Valve cover paint (Easy Mike)
Old 06-30-2004, 11:55 AM
gliot1
gliot1's Avatar
Received 1,443 Likes on 753 Posts
St. Jude Donor '12-'13
I used semigloss high heat paint. Fully strip the covers and clean (I used the dishwasher with excellent results). After painting take a medium frit sandpaper and sand off the paint on the fins. They came out like new and have held up over (3) years so far.
Old 06-30-2004, 03:08 PM
red topless gator
Default Re: L-82 Valve cover paint (gliot1)
Thanks for all the replys, I think I will try the semi gloss high heat paint..............LT
Old 06-30-2004, 03:54 PM
mvftw
mvftw's Avatar
I had mine powerdcoated semi-black, that way it will resist oil, gas & chipping and it shines right up
Old 06-30-2004, 03:55 PM
COMMANDER370
COMMANDER370's Avatar
Old 06-30-2004, 05:35 PM
page62
page62's Avatar
Default Re: L-82 Valve cover paint (Pauld)
Go for the polished look! They look cheap when they're painted black. I have a set of chrome LT-1 style covers and they look fantastic.
Old 06-30-2004, 08:27 PM
79MakoL82
79MakoL82's Avatar
Default Re: L-82 Valve cover paint (page62)
I have the black ones on my 79 L-82. I have the polished aluminum (LT1 style) on my Z28. I think they both look good, but the polished aluminum show dirt and grime faster and require more maintenance to look good. But when they look good, they do look GOOD.
That's my $0.02
To L-82 Valve cover paint
Quick Reply: L-82 Valve cover paint
