Anyone with 200-4R experience, please step inside...
St. Jude Donor '07
So I'm finally starting to ramp up to the project and I just want to know what things you guys had to buy to make it work. Currently I run a L48 w/th400, so moving cross member shouldn't be an issue. I'm also looking for places to buy, but I'm leaning more and more toward BTO.
I understand that many parts that BTO recommends I can buy through Chevy, but which parts and are they cheaper through chevy?
Things I'll probably need:
new yoke
tv cable
dipstick
dust cover
torque converter
lock up wiring
speedometer gear
and of course, transmission
Feel free to comment on any or all aspects I've brought up, or even things you saw in converting. Also, how'd you get it in? Just muscle it in or made something to lift it in?
new yoke
tv cable
dipstick
dust cover
torque converter
lock up wiring
speedometer gear
Re: Anyone with 200-4R experience, please step inside... (Buffalo Dude)
Why not just buy the whole turn-key package from BTO? And if you're in the area, let them install it. They'll even give you a 1 year warranty!
Re: Anyone with 200-4R experience, please step inside... (page62)
Take page up on his offer. Its not that bad of a job but some know how on getting the TV cable setup right sure helps.
You'll also need a way to get the shifter to move the gears correctly. Most just buy the conversion kit for about $90.
I am thinking of doing the 200 4R in my 66. I am running a TH 350 now.
What car and year is the 2004R in? I guess I will have to get one from the junk yard and who is BTO.
Re: Anyone with 200-4R experience, please step inside... (Veet 66)
What we're saying here is DON'T be a fool and do the junkyard thang! It only ends up being more expensive that what you would start out buying a turnkey package from BTO (Bowtie Overdrives) http://www.2004r.com
I've been here for over 2 years and still have not heard of a single BTO 200-4R cratering, grenading, giving out, whatever.
No I do not have a stake in BTO, I just have one of their trannys in my car!
I might go with a 800 HP rated 200R4 with transbrake from California Performance Transmission in combination with my new engine (being built right now)
St. Jude Donor '07
Re: Anyone with 200-4R experience, please step inside... (GrandSportC3)
From what it sounds like, I may waste more time tracking down less expensive parts than it's worth. Looks like I'll give BTO a call and see what they can do for me.
I do have one issue though: it seems as though BTO has speedo gears for $30, but I read in another post that GM sells them for $7? Is that correct, or just a fantasy?
Re: Anyone with 200-4R experience, please step inside... (UKPaul)
When you buy from BTO, they will put the correct speedo gears in it. Just tell them what rear gear you have and the size of your tires. They have everything needed to do the job. Best mod I have done to my 73
