Over Sized Screw Holes
The Bubba'(s) that there there before me used a multiple of different screws including sheet metal, wood, etc. for trim screws. I know I can fill the fiberglass ones and redrill the hole but what about the metal ones?
What is the best way to reduce these holes back to the orginial size so I can use the correct trim screws. :mad
Re: Over Sized Screw Holes (vettemack)
Put a piece of wire or a paperclip in the screw hole and then run the screw into it. the paperclip will reduce the size of the hole enough to make the screw grab.
