Temperature & Guage Question
Re: Temperature & Guage Question (olouieo)
Pull out the sensor and stick it in boiling water. If the guage reads around 212 it's correct. That or use one of the laser temperature readers.
St. Jude Donor '04 & '05
Or you can use the old fashioned method of using a meat thermometer in the radiator and compare it to the gauge reading. This should get you at least close.
Good Luck!
Good Luck!
Re: Temperature & Guage Question (ACECO)
Well sticking the sensor in bioling water would be too hard. I don't mind buying a Thermometer if I can get one for cheap ($20-). The meat thermometer in the radiator sounds like a cool idea but, how would you place it in the radiator so you can get a good read?
Location: The reason time exists is so everything doesn't happen at once
[Modified by 6t9l4t6, 7:48 PM 6/29/2004]
