80 Seat Belt Buzzer (where is it?)
"Rodstoration &am p;quot; In Progres
Noticed another member tracking down his buzzer in his mid-70s. I have the same issue on my 80... no buzzer when seatbelt is not on... Light comes on but no sound.
Any suggestions?
Any suggestions?
Re: 80 Seat Belt Buzzer (80TexasC3)
It's located on the right hand side of the fuse panel beside the flasher. The key warning buzzer is located in this unit also. I think both use the same buzzer.
Re: 80 Seat Belt Buzzer (Older Than Dirt)
Hmmmm
Then maybe something else is wrong... Key buzzer works...
If I don't put the belt on when starting... the light comes on for a few seconds but no buzz...
Your problem may be in the seat belt switch for it triggers the buzzer. I think the belt switch switches a ground (black wire from buzzer unit) completing the circuit. Check your belt switch and wiring.
