Clutch linkage Z bar bracket help
I was wondering if any one had a picture of the bracket that is welded to the frame the clutch Z bar pivits on. Im starting to do my conversion to a manual this week and this is the only piece i do not have. Anyone that has experiences making this or have any pictures of this bracket please let me know. THanks.
James Blankenship
Bigpeachboy@aol.com
73 corvette
James Blankenship
Bigpeachboy@aol.com
73 corvette
Re: Clutch linkage Z bar bracket help (James B)
James,
I bought mine from Dr. Rebuild. You can look on his site for a diagram of what the braket looked like. I have not yet welded it on, so I can't help you there. I found it too cheap in price to bother having one fabricated....
http://docrebuild.com/dr-r-web/aaa-home.html Be careful though, the prices are very outdated. I think liek 4 years old. Call or email to confirm the prices before ordering.
I got my bracket from Zip Products for about $12.
I have the body off of the frame right now and will soon be welding on the bracket. Short of mounting the engine block back on the frame, I am not sure how to find the exact spot where the bracket needs to be. Some of the later C3 frames have the spot set-up as a bolt on, but my 78 does not.
www.bigdogvettes.com
Re: Clutch linkage Z bar bracket help (groovyjay)
Groovyjay,
I am so glad you post both pics, because I had not thought about the Z-Bar clearing the headers!
I noticed that the Z-Bar is at an angle, which clears the headers, but, does it bind, being at the angle, or is that the way it should be?
Re: Clutch linkage Z bar bracket help (matchframe)
Thanks for the pictures grooveyjay, you are the man. I found the bracket in the zip products magizine so ill order thqat tomorow. Thanks guys
James
James
I am also converting from auto to manual but instead of replacing the complete pedal asembly I just cut the brake pedal pad and ad a clutch pedal.
Now I can´t put the brake sitch bracket back on since it interfere with the cutch pedal.
Do Automatic Vettes have a different brake light switch possition than stick shifts?? ........ Any pictures
Thanks
Thanks
Re: Clutch linkage Z bar bracket help (Pacha)
THE FREAKIN PARTS CALALOG GUY SAID THE PARTS I NEED ARE DISCONTINUED SO I HAVE TO MAKE THE STUPID BRACKET.
so im very angry now, and frustrated that this is going to take longer than usual
Chicago Corvette supply should have all you need. Had to have the bracket mount welded. I did my 81 from auto to 4 speed. Ecklers has some stuff, but its usually pricey.
Cheers
Bob
Cheers
Bob
