Removing Turn Signal and Tilt Levers (HELP)
"Rodstoration &am p;quot; In Progres
I would like to remove my turn signal and tilt levers as I prep to repaint my steering column. Would appreciate any help with how to do this...
Thanks!
Thanks!
Re: Removing Turn Signal and Tilt Levers (Vette-4-Life)
Vette-4-Life is correct. The 1977 through 1982 C3s had a screw-in tilt lever and a plug-in turn signal lever. The 1969 through 1976 T&T columns had both screw-in levers.
Re: Removing Turn Signal and Tilt Levers (Jim Shea)
So do I just pull out the turn signal? "pull hard?"
Cruise-In VII Veteran
St. Jude Donor '07
Re: Removing Turn Signal and Tilt Levers (80TexasC3)
I would just tape it off. Most time you can do more damage then it's worth and it's a pain to repair.
