Rally Wheel width
Rally Wheel width
I just found out my 69 has 8" Rally's on the rear and 7's in the front. The tires are 235x60's all around. Is this a clearance issue with thos size tires and the 7" wheels in front.
Re: Rally Wheel width (69'Silver)
You should have 8" rims all around. 68's used 7" wheels and it is basically the same car so you shoud be ok. 235"s are only one size over stock but each of these early cars are a little different. 255's hit my muffler and E brake bracket but others have no problem.
