No Turn Signals or Reverse Lights. I'm going nuts!!!
I just adjusted the back up bracket so my reverse lights would go of, now the reverse lights and the turn signals don't work. The running lights, headlights, and stop lights all are working fine. I checked the assembly manual to see if it was a separate fuse. The manual was no help.
My question is, is there 2 separate fuses (one for reverse and turn signal and one for running, headlights, and stoplights)??? Could it be something other than a fuse???
If I cannot get the car on the streets this weekend, I'll be :mad
Re: No Turn Signals or Reverse Lights. I'm going nuts!!! (Andrew)
The fuse panel is under the driver's side dash in the upper left. I am pretty sure that the reverse and signals are on the same fuse. If it is not with the signals...it might be with the hazard lights. I had a couple fuses blown...and I remember I had no reverse or turn signals. On the fuse panal, at least mine is marked with what it is for. Hope this helps!
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Re: No Turn Signals or Reverse Lights. I'm going nuts!!! (NJ 76 Project)
You could have a bad turn signal switch in the steering column.
