who is runnig a super charger
Re: who is runnig a super charger (76REDSTINGER)
single carb here.. 750 HP series right now.. and 1000 cfm HP series with my new engine that is being built...
Supercharger, but not listed on your poll... twin screw...
Attached but not installed in the car yet...
http://temp.corvetteforum.net/c3/zma...eng_lfront.jpg
St. Jude Donor '09
Re: who is runnig a super charger (GrandSportC3)
"poll to see how many are running superchargers
or turbos. for c3 only please".
Weiand 6-71 http://www.garaget.org/show.php?imag...-3488-1000.jpg
[Modified by Eriksson, 8:51 PM 6/26/2004]
Re: who is runnig a super charger (Eriksson)
Eriksson is that your car??? Love to hear more details about it. Transmission, gearing, how it runs, boost, blower speed, any dislikes???
Very nice car.
Very nice car.
Re: who is runnig a super charger (norvalwilhelm)
engine is an 355csb, pretty wild cam, iron heads, dual holley 600vac, T400 tranny, 4.10 gear ratio, it should deliver 5-7psi of boost according to the manual, but i have changed the pulleys so they only deliver around 2psi of boost right now... because im running with 10.5:1 pistons ... im gonna tear down the engine in a few weeks and install 7.5:1 pistons, then im heading for 16 - 18psi.
[Modified by Eriksson, 11:40 PM 6/26/2004]
You don't need the wild cam for supercharging. You want 112- 114 lobe centers to build boost but not that much duration. The boost will fill the cylinder, you need to contain the boost and build pressure.
Don't go below 8 to 1 compression, run 15% overdrive and 12 pounds of boost is plenty. That give about 14-1 compression under load.
I would O ring the block at those high boost pressure.
It is a nice motor and will get lots of looks anywhere you go.
Good luck and I am glad to see someone else in running a blower besides myself.
Lots talk about it but you and I are the only ones actually running that I know of.
This is my 4th year for my 8-71 and still can't get use to the incredible low end torque.
Double click to enlarge
the cam i have now was installed before i decided to buy a blower, the old cam i took out is usually used i blown enginges (anyway here in sweden )
so that one will be used again when i install the new pistons.
O - ring the block is on the "to do list". also an electric waterpump.
8 to 1 compression will i look a little closer on, sound like a good idea!
nice looking engine by the way
Thank you!
/Martin
Thank you!
/Martin
norval,forget about me.I have a question though, you running 15 over should put your boost way over ,sure not under? whats your pulley count?My new combo nearly finished, will be getting all the pics ready.
