Speedo adjustment for new gears
I recently went from 308 to 355 gear ratio. The stock speedo drive gear in the T350 has 21 teeth. I went up to 22 teeth and it appears the speedo is even further off?
Any knowledge shared would be appreciated
Re: Speedo adjustment for new gears (colorado1967)
You went in the right direction by increasing toothe count. You need to slow the speedometer down. I recently changed from 3.08 to 3.73 and changed the speedo gear from 21 to 25. I might need a 24 to make it accurate. You should be close with 22, maybe 23. In any case, due to differing tire diameters, its not an exact science.
There was just a post on this the other day.. I found this site to be semi helpful...http://www.tciauto.com/tech_info/speedo_gears.htm#350
The one in the post was:http://www.bgsoflex.com/speedo1.html
I'm still trying to figure out my speedo ger issue as well... mine's showing that i'm about 10mph faster than what I'm really going...
