Speedommeter repair, Can I do this myself?
Guest
Posts: n/a
I put a new speedommeter cable in the 71 last year. The odometer and trip odometer still don't work, a bad gear in the back or something. The speedo part works fine. Is this a do it yourself repair? What and where are the replacement parts available at?
Thanks guys
Thanks guys
Re: Speedommeter repair, Can I do this myself? (Rick Church)
There is an article about changing the odometer gears at CorvetteFAQ.com.
The gears are available from Dr. Rebuild - that is where I got mine last month. I have heard that Corvette Central also sells the gears.
I will be removing my dash next month to install a 1970's style cruise control system and inspect the brake booster and then I'll changeout the gears.
Roger
Roger
Re: Speedommeter repair, Can I do this myself? (RMS73)
I just did this repair on my 71. It's a lot harder to get the dash out than it is to replace the gear in question.
