Rear wheel bearing replacement cost
St. Jude Donor '07
Re: Rear wheel bearing replacement cost (jac1502)
If you take the housing off yourself and bring it/ship it in, around $450 for me. If you have them do all the work, probably around $800+labor. It's even cheaper if you decide to press and pack the bearings yourself, but unless you're wise to exact run-out specs and tolerances, I'd say let someone else do it. Van Steel does it for I think ~$225 each side.
I just did mine from bairs corvette $ 720. with shipping that was a completly rebuilt trailing. they turned them around in a day and a half
Just looked at pricing Wheel bearing assy. $ 150. per side same day shipping
http://www.bairs.com
What's the old saw about "If you have to ask, you probably can't afford it?"
I got VanSteel to rebuild my t-arms/bearing assemblies, but I took the body off the frame and had very good access and no cost for remove & replace.
Some jobs just aren't worth doing yourself...
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Re: Rear wheel bearing replacement cost (nd4speed)
Prices vary depending on who is doing the work. Where ever you get it done make sure they install bearings made in the USA. I prefer Timken bearings. Cheap non American bearings === Failure down the road.
