Radiator and Fan Advice
Old 06-24-2004, 12:27 PM
VTHokie77Vette
VTHokie77Vette's Avatar
Default Radiator and Fan Advice
Since I'm rebuilding the '77 and trying not to take any shortcuts, should I get a new radiator and fan? I've heard good stuff about the Be Cool Radiators and Electric fans. Which ones do I get?
Old 06-24-2004, 06:33 PM
AlwaysWave
AlwaysWave's Avatar
Cruise-In III Veteran
Default Re: Radiator and Fan Advice (VTHokie77Vette)
I'm well pleased with the DeWitt's aluminum radiator and Spal electric fans.
Old 06-24-2004, 07:50 PM
spikezz4
spikezz4's Avatar
I would suggest an aluminum radiator from Be Cool, and use 90-96 Corvette electric fans. Use the serpentine system that Vintage Air just came out with as a kit, or else source the brackets and stuff from a 1989 Corvette.
Spike
Old 06-25-2004, 01:32 AM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
Definitely go with a Spal fan. It is the best fan out there and will cool better than anything else. For radiators you have alot of good choices with Griffin, BeCool, and Dewitts. I personally am running a stock replacement that a previous owner placed in. It worked good before the Spal fan upgrade, but now with the fan the car never sees over 190 degrees. I just used the single 16 inch fan alot of others on this forum have the dual Spal fans.
Old 06-25-2004, 08:43 AM
VTHokie77Vette
Default Re: Radiator and Fan Advice (Sigforty)
Thanks for the input guys.
Old 06-25-2004, 10:29 AM
markdtn
markdtn's Avatar
Default Re: Radiator and Fan Advice (spikezz4)
Spike
I got a Griffin from DeWitts and used 96 C4 fans. I am using TPI serpentine system with an 85 alternator-)uses C3 plug).
To Radiator and Fan Advice
Quick Reply: Radiator and Fan Advice
