still got the "CLUNK"!
:mad ,Well,I have replaced the rear wheel bearings,all 6 U-joints,put in a poly "snubber",replaced the differential fluid with synthetic w/posi additive.And I still have a clunking sound when making quick turns,and it still makes a loud clunk when it slams into reverse when the RPM's are too high(typically when cold).I guess my tranny is out of "adjustment",or the rear end is going bad?I have a '79 with a TH-350.
Re: still got the "CLUNK"! (redson)
Anyone correct me if I'm wrong, since this is just a theory... I had a terrible clunk in my 86, replaced tranny, new U joints, totally rebuilt suspension w/ urethane, new wheel bearings all around, same clunk. I sold the car and never figgured it out. My 78 clunks and Im currently replacing the side yokes because they're 1/4"~1/2"+ worn. So heres the theory: When you put it in drive or reverse, it loads up the diff, causing the "squat", the side yokes slide out, and bang the pin on the way back in. Hence the clunk. I haven't got my car back together yet, so I can't prove anything, but I'm hoping it will go away.
Another thing to check is the T-arms bushing. had my '72's rear suspension worked on this spring and the mechanic said that the universals were going, but the biggest noise maker was a shot T-arm bushing. Even with all that there is still a small clunk, but it is very light compared to before the work.
I'm quessin' it's the side yokes. My 76 clunked then one day while pulling away from a red light the one side yoke snapped in two right at the diff. I went ahead and replaced both shafts while I had the diff out on the bench.
[Modified by Jack1976, 4:18 AM 6/29/2004]
[Modified by Jack1976, 4:19 AM 6/29/2004]
OK, I've had a clunk for almost a year now and it's driving me nuts. I did the same, I changed the differential mounts, I replaced the differential bracket and I replaced all u-joints. Still had the clunk, I removed the drive shaft and moved the differential by hand, I noticed almost a 1/2" play in the differential which caused the clunk sound. I was told my rear end may not be setup correctly so I ordered a new rearend. I just received a new Auburn posi but haven't installed yet, hopefully this will end the cluck. Will keep you posted. Might want to check the play in your rear end.
Damian
Damian
Re: still got the "CLUNK"! (StingRay6T3)
Damian
Damian
