Removing the A/C in an 80 vette...
St. Jude Donor '08
What needs to come off?
Can i still keep my heat?
Any info will be much help.
Thanks
:cheers:
David
Thanks
:cheers:
David
Re: Removing the A/C in an 80 vette... (88'Cubka)
compressor, lines, dryer bottle, condensor. That's about it, then you're stuck with the evaporator in the heater box. If you open the heater box you can remove the evaporator too, heat is a seperate heat exchanger, can stay in place..no problem. Just make sure you seal off the 2 little indentations in the heater box 1/2 where the AC lines went through (from the evaporator)
[Modified by Twin_Turbo, 1:05 AM 5/30/2004]
Cruise-In VI Veteran
St. Jude Donor '09
are your a/c parts any good, if so id be interested in them.
---Chris
---Chris
St. Jude Donor '08
Re: Removing the A/C in an 80 vette... (Today's problem is..)
Thanks TT.
Im not sure about the parts today's. I never put freon in the car to test it so im not sure.... I am going to keep the parts though just incase one day i get old and want AC :)
David
David
