Vaccum and heater core hoses
I have a 1977 corvette with a replaced engine.
When the engine was replaced, the hoses were not all connected.
need a vaccum hose diagram. Also, I have the location of one heater
core hose but the home for the other one is missing. Plez help! :confused:
Re: Vaccum and heater core hoses (77stingray)
I need help with this these hoses are simply laying inside me engine compartment! :(
Does anyone have pictures of the inside of their engine compartment that they could post so I could look at the location of the heater core hoses? :flag
[Modified by 77stingray, 11:11 PM 5/29/2004]
Not sure if this is what you're looking for, but in the following pic you can clearly see one of the hoses connecting to the manifold, and if you look carefully you'll see the second hose connecting to the water pump.
Hope this helps...
:cheers:
-Pedro
Hope this helps...
:cheers:
-Pedro
If you don't have A/C here you go.
At the other end, one to the waterpump and the other to the snout on the intake. They are different sizes (3/4" and 5/8") so you can't mix them up.
For vacuum this should give you some ideas.
[Modified by paul67, 8:17 AM 5/30/2004]
[Modified by paul67, 8:21 AM 5/30/2004]
