leaf spring rearch
leaf spring rearch
How can you tell if your rear spring needs to be replaced when the spring is removed? As far as I can tell the ride was fine,and the car did not sag in the rear but it is almost 30 yrs old. Has anyone ever had a leaf spring rearched? I can have that done real cheap. I removed it to replace side yokes and ring and pinion.
