Rotors arrived
Re: Rotors arrived (78 Vette)
You might check with where you got them - most places list two part numbers which means there are some slight differences. It also might be nothing to worry about.
Re: Rotors arrived (Older Than Dirt)
Good link I'm going to measure the offset right know. I did notice a difference between the two. The ones marked front were drilled out differently for the rivets. But the both have the mini drum on the inside. be back in a few.
Ok so for the record they are different the offsets differ 1/8 of an inch. Also the front have a thicker hub area. I guess they make one rotor to save time and money and machine the differences later. As soon as the pads get here I will fill in everyone on how they work. I went with the green EBC pads.
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
If you got them from SSBC, they are correct.
I thought the same thing to. Don't know why they do that,
but they also work super great for me. :thumbs:
