Eckler's Tach circuit board...problem
I just changed the circuit board with Ecklers part #36963 and now the tach reads 4000 rpm when it should read 1500 rpm. The old tach CB was working fine but since it was stock I figured I would swap it out while I had the dash open.
Any ideas ?
beside put the old one back in which I will do as a last resort.
Any ideas ?
Re: Eckler's Tach circuit board...problem (Pete76Shark)
I have the exact same prob. Seems that in '76 and '77 you need to pull the needle off the tach, and re-zero it, while the tach is powered up (KEY ON)
Mine reads stooooooopid numbers now too, after all that work :mad :rolleyes:
I hope that the only problem is that you need to remove the needle and set it at 0.
From my experience with Ecklers, I purchased one for my 79 and it did not work. I returned it and they sent a new one. The new one did not work either. I took my old one to someone who knew how to work on them and he got the old one fixed for a while. Now I just don't worry about it. All of that trouble and no fix.
If it is as simple as removing the needle, that procedure is very easy. Remember to pull on big end of the needle and don't touch the needle itself. They break very easy. :cheers:
Re: Eckler's Tach circuit board...problem (SanDiegoPaul)
I put the old one back in and will have to make a note not to buy this from Eckler's again should the stock board crap out..
I had to install the drivers side panel 3 times due to this... man thats a job and a half..
Thanks for the help
:flag
