Help on replacing plastic oil pressure line with Summit's SS kit
There was recently a thread where someone recommended replacing the plastic oil pressure gauge tube with a stainless steel one to prevent future disasters. This is the kit I'm referring to:
http://store.summitracing.com/partdetail.asp?part=2545
The engine end of it went on fine. I used the provided fitting to connect the line to the back of the engine. When I went to connect the provided fitting to the factory oil pressure gauge, that's when I ran into a problem. Those of you who have used this kit, how did you connect the line to the gauge? The fitting does not screw onto the back of the gauge. I went to Lowe's and looked for some sort of fitting that might work, but I had no luck. Any advice?
Re: Help on replacing plastic oil pressure line with Summit's SS kit (73'Vette)
I ran into the same problem.. I went to install a new plastic line kit. The gage fitting was a little different so it leaked. Fortunatly I had saved the old line so I had to re-use the old fittng. Luckily it sealed. The GM gage fitting is a little different than the aftermarket kits. I don't know what the fix is though. MIne is fine for now... I think the Last Detail sells GM line kits, but they are plastic.. BTW... I trust the plastic lines. I have NEVER seen one go bad.. Brass lines or copper lines will crack over time but not the plastic ones.
