doh. think the starter just hit the sh!77er
went to start it up and not much so i put the battery on 6 amps and tried to start and it barely started and then died. tried again and it rolled over once or twice and then gegegegegeggegegegege from the starter i guess..now that's all i get. Prolly some orielly cr@p from the installer.
Re: doh. think the starter just hit the sh!77er (munday)
My advice is to charge your battery overnight, then check it with a voltmeter before reconnecting it to the car.
From my limited experience, when the starter goes bad, it makes no noise whatsoever. You're probably dealing with a dead or drained battery, perhaps even a bad alternator.
How long was the car sitting before you attempted to start her? How long did you leave the charger on the batt??
Did you try to jump start your car?
What is orielly anyway? :lol:
Re: doh. think the starter just hit the sh!77er ('75 383 ElkGrove)
battery is a die hard, a couple years old at least 2, car only got started a few times last year, and has trouble pushing out the in dash tv when off.
