Chasing high RPM pinging
OK, a distributor rebuild has solved the timing problems, and I've set 37 degrees total mechanical advance (12 initial + 25 certifugal). Yet at high RPMs, I still have pinging. Any suggestions? This is a high mileage L82 (93K). A friend suggested that there may be carbon build up in the cylinders, and to blow out the carbon by dripping water into the carb. Whaddya think?
Thanks
Thanks
Re: Chasing high RPM pinging (Swamp Thang)
L82's varied in compression ration based on the year I think. What is the compression ratio?
You don't mention the vacuum advance, that could be your problem if you have too much vacuum advance but that would most likely bring a problem in mid RPM cruising as well.
I heard carbon build up can be a problem and careful use of water will burn it off.
If it's just a compression ratio problem than you can a.) retard timing even further, you may very well get better perfomance with 32-36 total regardless of pinging or not; b.) take the heads off and get a thicker gasket to raise the compression; c) find a gas station selling race gas or start purchasing toluene.
Is it off of the throttle? Vacuum advance might be adding to many degrees. I bought a Crane adjustable vacuum advance.
Re: Chasing high RPM pinging (gkull)
I'll stop on my way home this afternoon and take it for a test drive.
When you get it back on Tuesday, all will be well.
ps - Don't beat on my 266k mile Buick while I'm gone !!!
:D :lolg: :lol: :lolg: :D
Seriously, a small cup of water down the hatch while running WOT - can
blow out all the carbon, but you risk trouble - such as a chunk getting caught
in the valve seat, etc.
There is a fine line between setting timing for top performance and pinging.
I usually do NOT use a timing light - get it close (like you do) and tweek it in
by driving. If it pings slightly, just back it off a degree.
:seeya
:seeya
Back in the 70's when the best gas you could get was 91 0ctane, Eldelbrock
sold a water injection system. When the vacume droped and a rpm level was reached it would spray water down the carb (old idea from WW2 fighter planes) I bought one and it did stop the pinging on my 11-1 engine.
Re: Chasing high RPM pinging (w1ctc)
ARE you sure it's pinging??? and not another noise :skep: up your octane in
about 1/4 tank of gas and see if it goes away.. also if possible do a high
RPM shut off and read the plugs.... it could be a lean out at high RPM :thumbs:
Re: Chasing high RPM pinging (comp)
37 sounds a little high, try knocking it down to 35 and see if it goes away. My .02
[Modified by Surfer69, 8:48 AM 5/28/2004]
