whats the best primer
Re: whats the best primer (mikesfst69)
I don't know, but here's a TTT for you.
Also check out http://www.corvettefaq.com I believe there is a paint paper on there from Lars that you should read.
*edit* Spelling errors
[Modified by Stoge, 10:44 PM 5/25/2004]
The best primer is the primer that goes with the paint system that you will be using. You want to use a catalyzed primer.
Best primer??? how about the one that don't bubble up on you or cause other problems from some weird chemistry????
which one is THAT??? damn if I know.....
I don't even get along with a spray bomb all that well.....
GENE
GENE
