throttle cable help...again
Cruising
I posted a little while ago about my throttle cable being too long. Well I was told to bend the metal piece that bolts to the rod that bolts up to the pedal. I've finally gotten around to getting under there to do this, but how do I get that piece of metal out of the car with the throttle cable going through it? Do I have to pull the whole cable through with it? Thanks
Cruising
Re: throttle cable help...again (68stingray)
Forgot to add....the whole reason I am doing this is (1) the cable is obviously short and (2) the gas pedal stuck when I was driving it :eek: Anyone else run into this problem of sticking pedal and if so what should I do? It sort of scraps along when you pull the throttle open. More springs? Thanks
not sure about all the details you mentioned, but you should have 2 throttle return springs at the carb. (Safety measure I believe, in case one breaks). I had a sticky throttle once and as a temporary measure to get home I put on an extra return spring. It worked, but my foot got a little sore from pressing on the gas, and on the highway my speed would drift down from 65 to 55 periodically... :lol: I later discovered my throttle was getting hung up on the air cleaner base.
