turn signal woes
Re: turn signal woes (ZiVvmO)
check and clean your ground wire to frame attachments.example: my back lights weren't very bright, new bulbs didn't help much, so i disconnected the ground, cleaned up both surfaces, re-attached and everything works, much brighter now. the ground wires on these cars are just as important as the hot wire.
Did you replace the round flash unit? about $2.50 for one of these in O'Reilly's
[Modified by Gary79, 5:54 AM 5/25/2004]
Cruise-In V Veteran
Cruise-In VI Veteran
Check the contact plugs on all four corners. Clean the grime off. My right signal didn't work right until I cleaned the contacts well. No problems for last two years.
2018 C3 of Year Finalist
Ditto here on the bad ground. Had one side that would work intermittenly. Cleaned all ground points and even added a small ground wire, works all the time now, Chas
