Help!!!!! Dash removal question
Well this day started out easy all I wanted to do was put on a new dash pad and paint the gague bezel. LOOK WHAT HAPPENED OH CRAP!!!! Now I am doing the seats ,carpet and who knows what else!!!!!!!
Hears my problem I can't seem to get the drivers side lower dash panel out to get the Dash pad off how do I do it?????????? I am starting to get this bad feeling that the Steering collum has to be dropPed PLEASE TELL ME THEIRS AN EASIER WAY!!!!!!!!!!!!!!!!!!!!!!!!
Re: Help!!!!! Dash removal question (checklst)
Hi David,
You have to lower the column, but that is no big deal. Remove the trim panel under the column, and you'll find two bolts that connect the column to the dash. Loosen those bolts, and the column should drop some. If you still need more room, you can also loosen a couple of nuts (bolts?) on the firewall, and it should drop some more. If the upper dash pad is out, then the dash panel should come out without problems. Be sure you disconnect the speedo and tach cables, or they won't let you move the panel too much...
Good luck,
:cheers:
-Pedro
[Modified by Pedro'74, 10:34 PM 5/24/2004]
Good luck,
:cheers:
-Pedro
Re: Help!!!!! Dash removal question (nd4speed)
Just noticed that you said you want to "get the drivers side lower dash panel out to get the Dash pad off". You don't need to remove the driver's side panel, and in fact, if you wanted to remove it, it would be easier to remove the dash pad first. If the windshield molding and the passenger's side panel are out, the dash pad should come off (with enough "persuasion").
:cheers:
-Pedro
[Modified by Pedro'74, 8:46 AM 5/25/2004]
:cheers:
-Pedro
Re: Help!!!!! Dash removal question (Pedro'74)
Opps I forgot the pic, I just started the day wanting to change out the dash pad and clean up the gague bezel. Sheeeeesh talk about a snow ball down hill.LOL
I will sleep on it and start fresh tommrow I tried to get the pad out every way I could think of, I could force the old one out, but it's the new pad I'm worried about I would hate to damage it going back in!!!!!! Yakes just seemed wider at the bottom of the windshield frame if I could angle it downward a little. I do have the piller post out on both sides but no joy YET!!!!!
Thanks guys :banghead:
[Modified by checklst, 6:45 AM 5/25/2004]
The dash pad is an interference fit to get it passed the windshield A-pillars. Even with the pillar padding pieces removed. I think that the assembly plant put the pad in before the windshield glass was installed. One hint is to heat the pad with a hair dryer so that it would bend more easily. I was always concerned that a 30 year old pad would crack when trying to bend it. But if you have a new one to install, you won't have to worry about what happens to the old pad. If you are installing a new pad, it probably will take the stress of bending quite a bit easier.
Re: Help!!!!! Dash removal question (Jim Shea)
... I was always concerned that a 30 year old pad would crack when trying to bend it. ....
[Modified by multifast1, 3:50 PM 5/25/2004]
I had the same problem but now the dash pad is out! Go as far as you can over to the drivers side with the pad so you have as little of the pad as possible behind the pillar on the passenger side.
If you do not want to crack your dash, do this on a 90 degree day! I speak from experiance and almost wrecked a perfectly good pad. Once the pad is warm you pull down on the right while slightly pushing up in the middle and it pops right out. Easy to bend once it was hot enough.
Good Luck! I am just now getting mine reassembled because of the while I am at it excessive compulsive behavior common with Vette owners.
:nono: :thumbs:
:nono: :thumbs:
Re: Help!!!!! Dash removal question (1974ta)
Thanks guys, I got it this morning just like you said push it all the way over to drivers side and bend in the middle and out she came.
I will do your suggestion of the 90 degree in the sun for a few hours before the new install
THANK GUYS I COULD NOT HAVE DONE IT WITH OUT YOUR SUGGESTIONS. :smash:
