Anyone convert their C3 to serpentine?
Re: Anyone convert their C3 to serpentine? (1970-Bronze)
Not too hard. Check out a complete setup from a C4. Try Gruhala at
gruhala@jcn1.com
I used a March kit for looks. Excellent quality but a bit pricy.
gruhala@jcn1.com
The ORIGINAL and bestest
Toronto Events Coordinator
Re: Anyone convert their C3 to serpentine? (flynhi)
I also used a March kit, in my opinion nothing beats the look of polished billet aluminum pulleys. Very expensive though.
Cruise-In VII Veteran
St. Jude Donor '07
Re: Anyone convert their C3 to serpentine? (7t2vette)
I think there is a vettefaq.com topic on my old system. It's a pretty easy conversion. I believe one of the parts dealers has a kit for a pretty decent price.
Look at an 88 305 plan jane TBI camaro bracket system it had an air pump but will install with out it. You will need the water pump and an after maket reverse fan as well. On my 81 this was a perfect retrofit because it even uses the same ac compressor.
Location: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
I also used the March system, mostly for looks but I also used an elctric fan. There is also another company out there doing a system I think they're called zoops try http://www.zoops.com :cheers:
[Modified by 69shark, 12:23 AM 5/24/2004]
