While you're at it disease! Power Window Spring Missing!!!
Well, I just got through tearing my passenger side door apart to tighten up the side mirror. Getting that dang window out was a bitch! :mad Well after tightening up the mirror I realized that the power window motor had quit working. I pulled the regulator out and discovered that Bubba had broken the spring at an earlier date (found part of the spring, the piece that attaches to the rivet) and had not replaced it. NO spring on regulator! :eek: Now I know why it moved so slowly. So I guess that I need to order a spring. Any thoughts on the correct procedure for putting it in? Thanks for the help!
[Modified by LABulldog, 5:07 PM 5/23/2004]
