seat belt warning light 1969
Re: seat belt warning light 1969 (TFranchini)
Start by checking the relevant fuse and then by replacing the bulb. Sorry if I am repeating the obvious.
[Modified by Kevin Mason, 4:49 PM 5/22/2004]
The light is a spring loaded thing that you just push to turn the light ou. It's not connected to anything. I took mine apart when I had the instrument cluster out. The bulb was burnt out so mine did not work. It's OK now.
I've never taken one apart, but it's a simple "off/on" switch. If you have power to it when you turn the car on, and the "SEAT BELT" light comes on, the switch simply turns it off when you push the button.
I'd try fooling with the switch, and see how it works. If it can't be repaired, I'd start looking for another. Don't know if it is available or is reproduced. Hope this helps. Chuck
Re: seat belt warning light 1969 (Chuck Gongloff)
it does not turn off, cannot find part, is it just the button and spring which is everywhere in parts catalog
I'll give it a whirl......
Behind the push button and light there is a small coil with a lever arm that is made out of sprung metal that rest against a grounded contact point that completes the light bulb circut. When power is applied current flows thru the lever to ground, energizing the light bulb. The coil is energized when the push button is pushed, it pushes the lever against a contact point on the coil which completes the coil circut to ground. Due to the coil now being a magnet, it holds the lever thus breaking the circut to ground for the light bulb which causes the light bulb to go out. If you light is not going out could be a burned out coil or the lever is not hitting the contact point on the coil allowing it to be held in place due to its magnetism.
[Modified by 68rdstr, 9:47 AM 5/23/2004]
Re: seat belt warning light 1969 (68rdstr)
if you place something in the light stays off, like a toothpick, so does it mean that if you replaced the button will it work
I would say no, since the light is going out when you press the push button, that indicates the push button is working correctly. Its probably in the circuitry behind the push button.
Here is a couple of pics of some of my spare parts that show the little arm and coil.
I replaced all dash and instrument cluster bulbs including the seat belt warning on my 69 last summer. Although mine works, I have to press the button and hold it in for about 5 seconds before it will stay off.
Mark
Mark
Re: seat belt warning light 1969 (Burgundy 69)
what parts do you need to fix this issue, stays on the light, I guess the magnet is not working?
what parts
what parts
