Windshield Gasket or just sealer???
Does the windshield have a gasket that goes on each side upnder the trim, or does it just get sealer? www.angelfire.com/al/swhite7/temp.html. I just took the trim off and all the old stuff was cracked and fell apart. I'm not sure if it was a gasket that feel apart of if it was just full of sealer. If it's a gasket, where can I find one? Thanks for the help :cheers:
YBnormal...drive a vette
Re: Windshield Gasket or just sealer??? (Ybnormal)
Only one way to fix. Pull windshield off next scape all of the old sealer and rust from the windshield frame chances are the frame is all rotten. If it is then you must fix or replace with new frame. Tis is the only way of fixing leakes
