78 Tilt / Tele Column parts help
4th Gear
On parts diagrams for a C3 T/T Steering Column diagram from both Dr. Rebuild and CorvetteFAQ, both list these 3 items... 1) Lower Shaft Retainer 2) Lower Shaft Washer 3) Shaft Wave Washer. Both diagrams show these 3 parts adjacent to the Lower Shaft Mating Plate which secures the Lower Shaft Housing (Bearing Housing Support) to the Mast Jacket. Do these 3 items belong on a 78 T&T and where exactly do they go? The Lower Shaft Washer is also called the Support Thrust Washer, but it's hard to tell what actually thrusts against it. Any info is greatly appreciated, thanks! :confused:
