72 wiper door actuator, it was working fine a few days ago, now it stopped
72 wiper door actuator, it was working fine a few days ago, now it stopped.
I still have to figure out why the wipers stopped working, thank-you all for your responses, but now I need to get the Wiper door to open.
Suggestions?
Thanks
Vic
vadelsohn@cogeco.ca
Suggestions?
Thanks
Vic
vadelsohn@cogeco.ca
Re: 72 wiper door actuator, it was working fine a few days ago, now it stopped (1972corvette454)
Does the override switch below the steering col[RIGHT PULL DOWN] work? If it doesn't you prob have a vacuum prob. 2 vac lines go to a vac/elec assy just above your gas pedal on the speed/tach panel. Make sure the elec is plugged in. There are 3 ports on the assy. Looking from underneath, the left gets the BLACK hose[left of the diaphram] there's a BLUE DOT hose that goes in the MIDDLE port , the far right port has no hose
