MiniRat is finished couple more pics
Finally got it finished just have to put on harmonic balancer and water pump etc. Should be going in soon, I am seriously thinking about taking it to a machine shop new me that has an engine dyno and get it tuned there first before I put it in. :D
Here are the specs:
- Edelbrock Victor Jr heads port matched to Victor Jr. intake
- 400ci block bored 30 over, ARP main and heads studs, Clevite 77 bearings
- Scat 9000 crank, Eagle 5.7 rods
- SpeedPro flat tops 10.8 : 1 CR
- CC Extreme Solid Roller Cam XR280R 242/248 deg @ 0.050
- .608 in / .614 ex with CC Hi Tech SS roller rockers 1.6 ratio
- Holley 750 DP with ProForm main body
- Melling oil pump, Moroso oil pan yada yada yada....
Here are the specs:
Re: MiniRat is finished couple more pics (MotorHead)
Nice. What HP and Torque numbers to you think it will dyno?
Re: MiniRat is finished couple more pics (gdh)
Thanks guys, DD says 570HP and 550 FT/lbs I plugged in all the flow numbers and tried to be as accurate as possible, that said if I make over 500HP I will be happy
Re: MiniRat is finished couple more pics (Budman78)
Can't see the pics :cry Tried show picture, properties and Cut/paste.......
EDIT:Photobucket musta been down cos theyre back.
EDIT: nice collection of cardboard boxes! :D
[Modified by RHD '68 L89, 6:37 PM 5/21/2004]
Re: MiniRat is finished couple more pics (RHD '68 L89)
Great looking engine!! :cool:
What are you doing for hood clearance or is that too far in the future to think about??
Senior Member since 1492
Re: MiniRat is finished couple more pics (cardo0)
Awesome, nice work. :thumbs:
