72 Corvette 454, no wipers?
Took the vette out for a spin, it started to rain, I turned on the windshield wipers, the wiper door opened up no problem, but no movement from the windshield wiper blades, what a pain with all the rain. What do the Corvette experts recommend what to check for first.
Brgds everyone and Thanks.
Vic
vadelsohn@cogeco.ca
Vic
vadelsohn@cogeco.ca
Received 6,929 Likes
2015 C2 of Year Finalist
Re: 72 Corvette 454, no wipers? (1972corvette454)
dron't drive in the rain :D I have no clue for the ansewer other then it is 32 years old and wore out
[Modified by Nowhere Man, 9:02 PM 5/20/2004]
Re: 72 Corvette 454, no wipers? (Nowhere Man)
Rain-X! That's my windshield wiper if I happen to get caught in the rain. (It happened on the way home from the drag strip last year and it was good enough.)
Check any grounds first, then start chasing wires I guess...
try moving the limiter switch under the dash (*** in center of over-ride vacuum switches for head lamp and wiper door).
Every once in a blue moon, I have to turn the switch, and wipers are fine.
Hope this helps some.
Bill
[Modified by 72ls5fla, 9:41 PM 5/20/2004]
Bill
The ORIGINAL and bestest
Toronto Events Coordinator
Re: 72 Corvette 454, no wipers? (72ls5fla)
Hey Vic, got that window in yet? lol! I agree, first try the over ride switch under the steering wheel, it is the round **** between the two pull down switches. It is used to stop the wipers in the up position to change the blades, if it is switched off, the wipers will bnot work. Next I would check the fuse and wiring at the wiper motor. :cheers:
Re: 72 Corvette 454, no wipers? (7t2vette)
Also if these don't work check the switch on the firewall. When the door is opened it contacts the switch telling the system that the door is open and allow the wipers to come on. If the switch is broken or not being contacted the wipers will not work.
Re: 72 Corvette 454, no wipers? (Gordonm)
Eddie
