Would I be "Bubba" if...
...I drilled and tapped holes in my frame to mount my side pipes? :confused:
Perhaps somebody with the Hooker Side pipes could post pictures of how and where they mount to the car?
Thanks!
:cheers:
Thanks!
:cheers:
Re: Would I be "Bubba" if... (JohnS_77)
Are you kidding? That is not even nearly a Bubba. Now, if your sidepipes are made out of beer cans and you attach them to the frame....
Re: Would I be "Bubba" if... (R. Bruno)
:iagree:
thats not bubba at all, i wouldve probably done the same thing. Post some pics when you're done, sounds like itll turn out pretty cool :thumbs:
2018 C3 of Year Finalist
John, you should have gotten "T" headed bolts with the sidepipes. The head or "T" goes into the slots in the side of the frame. The bolts attach to the tabs on the side of the sidepipes. You can then attach the rubber isolators which will keep them from rattling and from transmitting noise into the interior. Did you get the sidepipes used? Charles
Re: Would I be "Bubba" if... (Mako72)
[QUOTE]...I drilled and tapped holes in my frame to mount my side pipes? [
QUOTE]
If you also drilled holes in the pipes and held them on with bailing wire you would get my vote for Bubba. :jester
Dane
[Modified by Enad, 6:42 PM 5/20/2004]
QUOTE]
Dane
10-4 John. Saw the name Hooker mentioned and thought that was what you were running. Charles
