Fuel Line Question
Fuel Line Question
Last week, I replaced the fuel line between the pump and carb on my '81. The new fuel line is contacting the lower radiator hose. Will this present any problems?
Re: Fuel Line Question (comp)
it will pick up heat :nono: you need to move, add if possible insulate a little :thumbs:
Re: Fuel Line Question (markdtn)
The replacement fuel line was difficult to install. I had to partially bend the line to get it into position. In the process of bending the line, it lost some of it's original shape.
What could I use to insulate the line from heat transfer? Is there something I could slide over it?
