Headlight doors just stopped opening
went to turn the headlights on, and the doors aren't coming up, but the headlights are on...where do i start troubleshooting??? thanks in advance. Herb
Re: Headlight doors just stopped opening (Redshark6974)
I believe you have a problem with you vacuum lines and I found a link for vacuum repair
http://iotech.no/corvette/technical/...ight_relay.htm
I hope this helps
I hope this helps
Re: Headlight doors just stopped opening (danboback)
Start with checking the hose at the valve at the rear of the engine where the vacuum lines split. If you've been fooling around behind the dash it could be at the switch too.
Good luck with it.
Good luck with it.
