Themostat housing questions
Having successfully warped my thermo housing, what replacement housing do you recommend?
The stock one, or an o-ringed model such as the chrome ones Mr. Gaasket sells. The chrome looks cheezy, but if it seals better I would probably use it.
For that matter, does anyone make an aluminum housing for use with an aluminum manifold?
Re: Themostat housing questions (comp)
got one from Summit, also has O-ring. it's anodized alum. :thumbs:
What's the part number? I have to replace a ugly rusty one
Steve :steering:
Muchas gracias, comp.
Re: Themostat housing questions (Kevin Mason)
Does anybody make a proper, cast-iron thermostat housing that's properly angled for the C3 WITHOUT the threaded hole on top for the TV switch?
[Modified by The Dude, 9:27 AM 5/20/2004]
2018 C3 of Year Finalist
Re: Themostat housing questions (The Dude)
After struggling with leak after leak due to warpage, I threw the chromed alum/gasket one I had as far as I could. I got a cast iron one (without the threaded hole on top) from the local auto parts store and have not had a leak since. This was before the o-ring type became common. They may be the answer if you want the chrome look. Charles
Re: Themostat housing questions (Mako72)
It's easy to fix a leaking themostat housing. Take a piece of emery paper, a 8 x 11 inch sheets works great, using masking tape to tape the sheet to any flat surface then start drawing the thermostat housing across the emery paper, in one direction only. Don't start rocking it back and forth.
Place the housing flat on the emery paper and slowly draw it towards you pushing down and keeping it as flat as possible.
Keep looking at your work and you will see the high spots being ground off and the low spots slowly disappear.
Take your time and in a few minutes you will have a flat housing that seals.
I prefer the O ring housing but even they need flattening.
[Modified by norvalwilhelm, 1:22 PM 5/20/2004]
Re: Themostat housing questions (norvalwilhelm)
Actually that was what I would do, but eventually it would start to leak again. Charles
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,238 Likes
Actually, I didn't want the chrome look. I like things as stock-appearing as possible. Actually, Norval, would a sanding block work for flattening the thermo housing?
Norval, everyone - thanks for the advice. Don't mean to forget everyone's names.
Here's a GM part# for an unpolished aluminum T-stat housing - #10108470. No O-ring . It's the same piece that comes on the ZZ4 crate motors. Bought mine from GMpartsdirect for <$5 (a supporting vendor). ;)
