Cutting the front springs?
Old 05-17-2004, 06:51 PM
03ki11er
03ki11er's Avatar
Default Cutting the front springs?
I would really like to lower the front end about 2''. I've heard that cutting the coils is the fastest and cheapest way to do it. I was wondering if anyone has done it and if they could give some tips. I guess what im really trying to ask is if it's easy to do! Thanks! :cheers: :party:
Old 05-17-2004, 08:19 PM
crf311
crf311's Avatar
Default Re: Cutting the front springs? (03ki11er)
2" drop is a lot to drop. You will probably end up with clearance problems if it is going to be a street driven vette. You can use a cut off saw, hack saw if you are strong or evn a torch. If you use a torch put the spring in a bucket off water to keep the heat down. I wouldn't use the torch method but I have heard of people doing it this way. I would start by cutting a half coil at a time and reinstall to check height. Then repeat until you get a height you like. Remember when you cut the springs your ride will get rougher.
Old 05-18-2004, 12:00 AM
LiveandLetDrive
LiveandLetDrive's Avatar
Default Re: Cutting the front springs? (crf311)
No torch! Even in water there will be some of it adversely affected by the heat. As long as you have a new, sharp blade, a hacksaw will be very easy. A dull blade took me 3 hours (dumb I know, didn't have any way to get to the store once I'd started) but when I did the other side with a sharp one, it took 10-15 minutes. A cutoff wheel or something would be ideal also. If I were you, I'd try cutting one full coil first for that amount of drop, but be VERY certain you want it, as you can't uncut! And have a backup plan if it decides to drop more than you expected.
-Chris
Old 05-18-2004, 12:07 AM
comp
comp's Avatar
Default Re: Cutting the front springs? (LiveandLetDrive)
:iagree: no torch, better to sweat :thumbs:
Old 05-18-2004, 11:14 AM
03ki11er
03ki11er's Avatar
Default Re: Cutting the front springs? (comp)
Sounds good, ill cut half a coil at a time and go from their. Thanks guys! :cheers:
Old 05-18-2004, 11:20 AM
Ozzie71
Ozzie71's Avatar
If you do a quick search in the archives for "springs" you will find plenty of useful info on this topic.
cheers
Mick :thumbs:
Old 05-18-2004, 01:14 PM
Cali,68,L-79
Cali,68,L-79's Avatar
Default Re: Cutting the front springs? (Ozzie71)
Done this myself, look at my pics on my webpage.
Old 05-18-2004, 01:54 PM
The Dude
The Dude's Avatar
A 4" cutoff wheel in a suitable die grinder will go through the spring material like a hot knife through butter. Almost. :yesnod: And the heat caused by the froction of cutting is very localized unlike using a torch.
Old 05-18-2004, 02:52 PM
Mike Mercury
Mike Mercury's Avatar
Default Re: Cutting the front springs? (The Dude)
what portion of the spring is the best to cut, the top or bottom?
Old 05-18-2004, 05:01 PM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Cutting the front springs? (Mike Mercury)
The bottom, where the coil spacing is larger.
Old 05-18-2004, 07:22 PM
Mike Smith
Mike Smith's Avatar
Default Re: Cutting the front springs? (Cali,68,L-79)
Cali -
How much did you cut your coilovers, and how much drop did it give you?
Thanks
Old 05-19-2004, 11:22 AM
Mike Mercury
Default Re: Cutting the front springs? (Mike Smith)
Jughead;
:cheers:
To Cutting the front springs?
Quick Reply: Cutting the front springs?
