WooHoo...Look what i broke....
Friday night off of a stop light...luckily i was not at cruising speed...not too much damage...u-joint sheared...half shaft did a bit of damage....
Re: WooHoo...Look what i broke.... (1Bad69)
I think you got off pretty good with little to no damage!!!!
What kind of a joint was it?
I get those bad images in my mind of that happening all of the time.
Re: WooHoo...Look what i broke.... (Fevre)
Chris...i wouldnt feel so bad if i was on it, but i just pulled away from the light like anyone else and BANG....
Re: WooHoo...Look what i broke.... (turtlevette)
Now you have an excuse to make the underside of your car as shiny as the topsides. :cheers:
Canadian Events Coordinator
I feel your pain. I've done it twice! Imagine if I had the torque that you have...heh heh heh.
I have a cracked battery box because of u-joint failure...
It sucks, but you'll have to replace the joint and shaft at most.
Good luck, Les :cheers:
Re: WooHoo...Look what i broke.... (Stewart's74)
You must have heard about PhotoShop ?, great little tool for making pictures veiwable :lol:
Re: WooHoo...Look what i broke.... (MotorHead)
Now you can go out an buy those carbon fibre ones that GrandsportC3 (Olivier) has. Not only are they light and cool looking, they will cost us Canadians a small fortune @$600 US for the pair.
That's why you want to use SPICER U joints without grease fittings. Nothing else comes close. You can't cut corners on half shaft U joint.SPICER..... Spicer. or Spicers
Re: WooHoo...Look what i broke.... (Larry B.)
Wow that sux, Mike. Well, at least it was at low speed.... minimal damage.
Hey - at least we finally get to see the dirty side of your vette. :lol: :seeya
Re: WooHoo...Look what i broke.... (gdh)
Hmmm....., maybe it's time to change mine! I agree spicer the way to go!!! No zerk fittings for me thanks. :eek: :eek: :eek:
hang around a track a little, you'll see lots of drivetrain parts including half shafts let go before U joints, the point being that with the tq. you engine produces and given that fact that it or a combination of things severely cracked your fibreglass rear spring the other year and led you to replace it with a steel one, there has to be some serious metal fatigue setting in why not look at replacing both halfs and u-joints - the carbon fibre was a joke although I wish I could afford them for myself. :cheers:
i am replacing the 2 1/2 inch shafts with bigger ones...also all 4 u joints with heavy duty ones...its a start...
That's what I was going to suggest ... the later model shafts that are slightly larger.
I had trouble finding the Spicers near me - special order for my parts store.
I ended up using the cheaper Brute Force non-greasables - but mine is a SB.
Re: WooHoo...Look what i broke.... (Summerfun)
i get a lot of stuff from a local guy that has been dealing Vette parts forever...he had them laying around....100 bucks each including the yokes...
