Lectric Limited single wire ignition
Is anyone here using the Lectric Limited single wire electronic ignition? If so how do you like it and was installation as simple as they say? I'm going to go to pointless ignition in my '72 base motor completely stock coupe and want the single wire hookup since it is an NCRS type car. Thanks.
Re: Lectric Limited single wire ignition (JScott)
I have had it for about A month. It was very easy to install. Car run's great I have A 72 350 4-speed :cool:
Cruise-In V Veteran
Cruise-In VI Veteran
I put mine in last July 4, drove it until 11/1 (winter hibernation) and been driving her again since April 19. No problems for me. Easy install- good luck with your project. Here's some pics:
Kit (My 1/4 in mini-socket. And I didn't need lead wire- used what I had.)
Opened kit
Before points removed
Going pointless (weights cleaned up a bit, too.)
Before with rotor on
After with rotor on
Opened kit
After with rotor on
Put it in my '70 last summer. Very easy install and I like the one wire look. Car seems to start a little easier than with the stock dual points.
[Modified by VETFOR4, 3:06 PM 5/18/2004]
[Modified by VETFOR4, 3:08 PM 5/18/2004]
St. Jude Donor '05
Re: Lectric Limited single wire ignition (VETFOR4)
Is this easily done? Can a goofus like me do it? Any tikming adjustments needed once complete etc...or is it take off and put on. Then it runs great??
Thank
Thank
