'74 Torque Specs.
Cruising
'74 Torque Specs.
I'm in the middle of replacing my rear spring and the rearend cover and I have the differential cross member off the car. I need to know what the torque specs are for the 6 bolts that go through the cross member (2 to the frame and 4 to the rearend cover). I'm still waiting for the shop manual to arrive. I was also wanting to know what the origonal color for the rally wheels were, the ones on the car have been painted (I figure this should be a inexpensive project until I can afford to do the brakes).
Thanks
Thanks
Cruising
Re: '74 Torque Specs. (wsnider74)
Sorry I should be more specific I have a 1974 with a 350 auto, I will also be posting a picture of the rear end diff. to see if someone can tell me if it is a limited slip or positrac.
