Side window adjustments
I've had gaps in my passanger door window at the upper front ever since I've had the car and adj. over and over, can never get it closed properly,
anyone else have this problem or is my windshield frame out of wack......
it was replaced.
it was replaced.
Re: Side window adjustments (motown 71)
Re: Side window adjustments (lone73)
good luck! I spent a day on this on my '78 for both sides. They seem right when the door panel is off; you put in on; they need readjustment. PITA!
Re: Side window adjustments (gliot1)
I finally ended up just adding weatherstripping... :confused:
