testing elec window switch...?
to jump the wires at the switch...
which colors do you jump to make it go up?
which do you jump to make it go down?
thank you...
thank you...
Re: testing elec window switch...? (SIGNGUY)
Don't know about yours (could be same), but on a 81 the pink wire is hot (common) to both switches. On the left hand door brown is up, dark blue is down. On the right hand door tan is up, light blue is down.
Re: testing elec window switch...? (Older Than Dirt)
According to the '80 shop manual, dk blu is up and brown is down for the drivers side. Not sure if the manual is correct though...
S-Guy If its like a '71, there's a relay on the pass side center console thats in the window circuit. Its below and in front of the radio. Has several push on connectors. Maybe 1 loose?
Re: testing elec window switch...? (sjr1971)
thanx guys...
ok...1st of all...we're talkin the pass side window...
and also...there is a relay?
whats it look like?
how do i test it?
i have a 79...
heres more info...
everything in door is less than 1 yr old...
new motor, regulator etc...
worked great until yesterday...
took a ride in the mornin...window worked fine at 1st then i went to put it up and it dragged a little and stopped...
i played with the switch...up/down, up/down repleatedly...nothin...dead...
then as im doin this it seemed to "catch" and started up slowly and stopped dead...
now...nothin...
whats it look like?
how do i test it?
i have a 79...
heres more info...
now...nothin...
well i just got home from the shop and it is fixed...
just my luck tho...it WASNT the switch...it was the motor... :rolleyes:
it had water in it...since i dont drive my car in the rain i have to assume that it happened from washing the car...
any ideas on how to prevent this from happening again?
other than by not washing the car!
