Riddle me this......
Hey guys,riddle me this.......i have red and black battery cables.......red one on passenger side, black one on drivers.....black one has a green screw-in plug(kill switch?)....they both have top mount style clamps........the red one goes out the battery box and screws(grounds?) to my frame......i cant see where the black one goes but i do have continuity at my battery cable that hooks to my starter hot pole(the big one)..........which one is my positive cable red or black? :confused:
Re: Riddle me this...... (Simba)
They were both black from the factory. The one that goes to the frame is the ground. Rather than Bubba, red may have been the only premade cable available at the local parts house. Crimpers for 4/0 are expensive.
The real answer is what is on your battery. Each terminal should have a marking ( + or -). I agree with the previous post - hopefully, bubba just put a wrong colored wire on the negative terminal. The positive cable is about 3 - 4 feet long and winds around up to the starter.
Re your question: It sounds to me like your positive cable is black! It should have the + near the terminal on the battery also.
Re: Riddle me this...... (Z-man)
There was no battery when i got the car.......and to change the post orientation all you have to do is spin the battery around.....and i automatically assumed red meant positive.........how careless of me .....so i hooked the battery up backwards.......and poof!!!!!!!! i have the battery in correctly now and the car cranks and it didnt fry my alt again.....so now what else did i fry? any ideas?...........
[Modified by Simba, 1:27 AM 5/14/2004]
The radio and electrical motors (wipers, elec windows etc depend on polarity for direction) should be the only things which are polarity conscious. I dont think turn signal a re affected but the flasher canister is easy to change.
Good luck!
:cheers:
Good luck!
:cheers:
