Lower radiator hose steel coil
Dude at NAPA said they don't put coils in lower rad hoses anymore so that's why the one I was going to buy didn't have one inside. I was thinking he doesn't know what he's talking about so I didn't buy it. So, it does need a coil, right?
Brett :thumbs:
Brett :thumbs:
Re: Lower radiator hose steel coil (Brettmc)
Yes, it needs a coil. Only the cheap ones come without it. I would suggest getting the GM part for this - you know it will be right.
Brian
Brian
the new formed hose's are a lot better stuff.. i kinda like knowing the wire
is in there to keep hose from collapsing.... i haven't had one do it that didn't
need replaced .. so it's back to time and mileage of hose's and belts and if
you don't know replace :thumbs:
Re: Lower radiator hose steel coil (comp)
Hello, I agree you need the coil. those hoses get spongy when they flex alot and the coil keeps them from collapsing. I think Car Quest auto parts still has the ones with the coil. they are a parts house near Chicago. If you can't find one let me know and I'll check with them and send you one.
Re: Lower radiator hose steel coil (markdtn)
I ran into the same problem, only chepa hoses without coils and was told the same thing by Kragen (which is pretty much the bottom of the barrel IMHO). So I ordered a Goodyear hose from them that was around $25 :eek: and still no coil! I ended up cutting the coil out of the old and putting it into the Goodyear. It was a little bent up from jamming it in, but it has worked without any problem.
I had the NAPA owner call his Goodyear rep and they said the new hose material doesn't soften with age, and they only use a coil in the larger diameter hoses. Joe
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Get a GM part with the coil in it. :yesnod:
If you're looking to keep it original, then by all means, go with the GM replacement as others have suggested.
If you're interested in aftermarket items, I'd like to suggest you get a SS hose kit from Summit or whomever. I bought the Summit SS corrugated black powdercoated hose, with the aluminum covers. It was a little over $100 bucks.
It is a little complicated to install at first, but I like the look, and reliability of the SS hose. I've had them on for more than 3yrs. without any problems.
Re: Lower radiator hose steel coil ('75 383 ElkGrove)
I looked all around for a lower rad hose with the spring coil in it and was unable to find it - If you buy a new hose you wont need it but over time the hose will get soft very fast and it could be a problem - I called GM and the replacement hose did not have the spring in it - I ordered the correct hose from ZIP - I would have went for a hose with out the spring, but changing that lower rad hose on the 1980 is a pain in the neck :)
Re: Lower radiator hose steel coil (RATT7)
Brett :thumbs:
Just for your info Brett, I had to trim my lower hose by almost 3" to fit without kinks or flat spots . I used a cheapo Pep Boys hose (no spring) - because I'm cheap. :D After a dozen trial fits I realized that triming was needed. :yesnod: Cut over 2&1/2" and could have cut 3".
Sprayed a little water on hose and radiator fitting each time and it really helped to slid things along. :yesnod:
Re: Lower radiator hose steel coil (cardo0)
I went with one of those stainless steel flex hoses for both top and bottom rad. thery are a bit $$ but will last forever and sure look great !!
Re: Lower radiator hose steel coil (motown 71)
I bought a lower hose from NAPA that had no spring for my big block '71. I have driven it in 100 degree weather and had no problem. I cruise at 3500 rpm and no cooling problems. I don't think the coil is needed.
Re: Lower radiator hose steel coil (henderjl)
Brett :thumbs:
I just put a new lower hose on my 76.... it didn't come with a coil either, and my old coil was so corroded and nasty I didn't want to use it. I also trimmed my hose about 1 1/2" to make a nice fit. I guess I'll keep a watchful eye on it, but so far it seems fine, of course its only 3 weeks old.
:cheers:
Loren
:cheers:
Loren
