Carpet install
Old 05-13-2004, 10:33 AM
mox 77
mox 77's Avatar
Default Carpet install
I now have an interior kit from Willcox, including the carpet. I also ordered, and have, the sound deandening kit and heat barrier material. When the carpet finally arrived, I found the carpet material already has a
jute (?) material applied its backside.
My question is will all this fit under the carpet: heat barrier, sound deadening, and carpet backing? I know someone out there has done it, or at least tried.
Any help appreciated.
Bill
Old 05-13-2004, 11:40 AM
Stewart's74
Stewart's74's Avatar
Default Re: Carpet install (mox 77)
I bet it may be too thick. I know people have removed the jute for carpet to fit with heat barriers. But....different carpet vendors have different size tolerances, yours may fit.
Old 05-13-2004, 11:50 AM
Edzred72
Edzred72's Avatar
There probably will be areas where you will have to remove a portion of the jute for parts to fit. Especially under the seat tracks. The mount bolts will be too short. OR...buy longer bolts.
Old 05-13-2004, 12:29 PM
machineg
machineg's Avatar
Bill
I user both, It fit really nice. I did have to trim a little on the door sills. Here is a link to my web page with a few pictures on page 2 or 3. This was a nice upgrade to not have the loud road noise and heat. good luck
Mark http://www.cardomain.com/member_page...=405302&page=1
Old 05-13-2004, 02:51 PM
mox 77
mox 77's Avatar
Default Re: Carpet install (machineg)
Wow, Mark....great cars!!!!
Thanks to all for the suggestions. I'm going to give it a try and work slow and carefully.
Bill
To Carpet install
Quick Reply: Carpet install
