cooling a zz4
cooling a zz4
Any zz4 owners out there..I was wondering how do you keep it cool?Electric fan..if so what size and cfm's? standard 4 blade fan? flex fan? do they run hot ..like some of the old engines in traffic?
Re: cooling a zz4 (newbe60)
I installed the ZZ4 in my 79. I did replace the radiator with a 4 row. Other than that, using stock configuration. Engine runs at 180 degrees, never have had a problem with running hot.
Cruise-In IX Veteran
I installed a Stewart stage 2 water pump and ran the stock fan with the stock radiator in my 71 for a while. I just recently installed a 16 inch SPAL fan and I love it. It really cleaned up the engine compartment, and the only draw back is the power it took so now I upgraded the alternator.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: cooling a zz4 (Sigforty)
I have the ZZ4 in my 1980. I have the stock type radiator, an Edelbrock aluminum water pump. I have run with the stock belt driven fan and now have the dual 11" Spal's. Both cooled the motor just fine.
We built a new crate ZZ4 to ax. 430 HP and cooled it with an aluminum radiator and a set of GM fans from a 1990 Corvette. We sourced them at a swap meet and replaced both motors with new ones from a Chevy dealer.
The ZZ4 was sold when we decided to use the LS6, but we are keeping the same cooling system.
Spike
Spike
Re: cooling a zz4 (spikezz4)
No ZZ4 here, but always ran at 210. Installed a "Super Kool Waterpump" and consistently stay at 180 now. Something to think about just in case. :)
zz4 with hotcam...
stock radiator
stewart stage II pump and dual 11" spal fans kit
No problems!! Runs between 175-200..fluctuating as the fans turn on nad off...
stock radiator
