T-top trim removal
T-top trim removal
Im in the process of doing the body work on my 69 coupe for painting and the trim on the t tops is a little scracthed up so I thought I would remove and have cleaned up. Does anyone know how to remove this trim without bending it.
Re: T-top trim removal (mikesfst69)
Very carefully. It can be done with a hammer and a blunt and very flat chisel. Don't let it slip off of the edge or you will have a scratch. Just start at one end and slowly tap it off making sure that you don't bend them. Good Luck, Craig :cheers:
